Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Traverses a Record Set to Close Service Requests >
Defining a Decision Condition for the Decision Point
This task is a step in Defining a Workflow Process That Traverses a Record Set to Close Service Requests. In this topic you define a decision condition for the decision point. To define a decision condition for the decision point
- Click the Yes connector.
- In the Properties window, set the Type property to Condition.
- Right-click the Yes connector, and then choose Edit Conditions.
- Define the following decision condition, and then click Add.
Property |
Value |
Compare To |
Process Property |
Operation |
Greater Than |
Object |
NumAcceptedRecords |
Value |
0 |
This decision condition handles the situation where the query returns no records. If this condition is met, then the workflow process runs the No connector.
Property |
Value |
Compare To |
Process Property |
Operation |
All Must Match (Ignore Case) |
Object |
noRecord |
Value |
false |
This decision condition determines when the workflow process reaches the end of the record set in situations where the query returns at least one record. For more information, see Creating a Decision Condition on a Branch Connector.
- Click OK.
- Click the No connector. Make sure the Type property in the Properties window is set to Default.
