Siebel Business Process Framework: Workflow Guide > Example Workflow Processes > Defining a Workflow Process That Creates an Activity for a Sales Representative >
Creating the Workflow Process
This task is a step in Defining a Workflow Process That Creates an Activity for a Sales Representative. You begin by creating the new workflow process. To create the new workflow process
- In the Object Explorer in Siebel Tools, click Project.
- In the Projects list, create a new project named Workflow Examples.
- Make sure the Locked property contains a check mark.
For brevity, example workflow processes in this book use the Workflow Examples project. In a development environment, you can use a project that more closely meets your development requirements. For more information, see Using Siebel Tools.
- In the Object Explorer, click Workflow Process.
For more information, see Object Hierarchy That Workflow Processes Use.
- In the Workflow Processes list, right-click, and then click New Record to create a new workflow process using values from the following table.
Property |
Value |
Process Name |
Large Opportunity Creates Activity |
Workflow Mode |
Service Flow |
Business Object |
Opportunity |
Project |
Workflow Examples |
For more information, see the topic about the Workflow Process object type in Siebel Object Types Reference.
- Choose the File menu, then the Save menu item.
