Siebel Business Process Framework: Workflow Guide > Manipulating Data in a Workflow Process > Passing Data to and from a Workflow Process >
Passing a Parameter from a Workflow Process to a Global Variable
To access and pass a parameter from a workflow process to a global variable, Siebel CRM can use a business service. If it uses a Workflow Process Batch Manager task to update a global variable, then each of these tasks is a separate user session and a subsequent task might not be able to access this update. For more information, see Using a Script to Access Parameters for a Workflow Process.
