Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Administering a Task UI >
Allowing Task Transfer
Siebel CRM allows a user to transfer a task UI to another user, by default. If you configure Siebel CRM to not allow a task transfer, then it makes the owner field read-only and disables the Transfer button for the current task item that it displays in the Inbox Items List view. To allow task transfer
- Log in to the Siebel client with administrator privileges.
- Navigate to the Administration - Application screen, and then the Tasks view.
- In the Registered Tasks list, choose the task UI where you must control task transfer.
- In the Responsibilities list, choose the responsibility where you must allow task transfer, and then make sure the Allow Transfer option includes a check mark.
To disable task transfer, make sure the Allow Transfer option does not include a check mark.
- Step off the record to save your modifications.
