Siebel Business Process Framework: Task UI Guide > Testing, Troubleshooting, Deploying, and Administering a Task UI > Administering a Task UI >
Deleting a Deployed Task UI
This topic describes how to delete a task UI that you deployed to the Siebel client.
To delete a deployed task UI
  1. In the Siebel Client, navigate to the Administration - Business Process screen, and then the Task Deployment view.
  2. In the Active Tasks list, query the Name field for the task UI you must delete.
  3. Click the task UI, and then click Delete Task.
    CAUTION:  Deleting a deployed task UI affects running instances of this task and might corrupt data. If you must delete a deployed task UI, then it is recommended that you deactivate the task first, and then delete it. For more information, see Deactivating a Deployed Task UI.
Siebel Business Process Framework: Task UI Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
