Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration >
Setting Up Integration Users
Administrators must designate integration users. These integration user credentials are used by the Siebel application to accept inbound Web service calls from the Oracle Application Integration Architecture product. Integration users are used by the inbound Web services to log in and to create, update, or query records in the Siebel application. You must also set up integration user credentials in the Oracle Application Integration Architecture product that you are using.
To set up an integration user
  1. Navigate to the Administration - User screen, then the Employees view.
  2. In the employees list, select the record for the employee who you want to set up as an integration user.
  3. Select the check box in the Integration User Flag field for this employee.
Siebel Communications Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
