Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration > Setting Up the Workflow Monitor AgentThe subtopics in this topic describe Workflow Monitor Agent setup tasks. Configuring Workflow Monitor AgentUse the following procedure to configure Workflow Monitor Agent. To configure Workflow Monitor Agent
Configuring Default Tasks for Workflow Monitor AgentServer Manager contains a parameter called 'Show Advanced Objects' that controls the display of all the objects that are marked for the advanced user. Workflow Monitor Agent has a parameter called 'Default Tasks' which has been hidden and is available only to advanced users. Use the following procedure to reveal this hidden parameter. To display the Default Tasks parameter
Starting Tasks for Workflow Monitor Agent for Customer SynchronizationUse the following procedure to start tasks for the component that is online and enabled. To start tasks for Workflow Monitor Agent
After about five minutes, check for log details for the task for the new workflow monitor component Workflow Monitor Agent SWI by navigating to the Administration - Server Management screen, then the Tasks view. If there are errors, then check to see whether all configurations have been properly performed. |
| Siebel Communications Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
