Siebel Communications Guide > Overview of Siebel Communications > Configuring Communications, Order-to-Cash, and Master Data Management Integration > Performing Required Tasks for the Master Data Management PIPThe tasks in this topic are required if you are using the Master Data Management PIP. Activating the Workflow PoliciesTo activate the workflow policies, follow this procedure. To activate the workflow policies
By default, the Workspace Release Flag user preference is set to N. If you want to release products into the Siebel application automatically, then you must change this preference. Customizing the Workspace Release FlagTo customize the Workspace Release flag, follow this procedure. |
| Siebel Communications Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
