Siebel Communications Guide > Fraud Management in Siebel Communications >
Viewing Fraud Alerts in Siebel Communications (End User)
When a back-office application flags an account for fraud, Siebel Communications receives a fraud alert and fraud alert details.
In the course of investigating fraud, end users review the fraud alert to determine the type of fraud that might have occurred. End users then discuss the fraud alert details, which contain the specific data alleged to be fraudulent, with the customer.
To view a fraud alert, follow this procedure.
  1. Navigate to the Fraud Management screen, then the Fraud Alert List view.
    Some fields in the list are described in the following table.
    Field
    Comments
    Fraud Event
    Displays the condition that indicates suspected fraud. The value in this field depends on the value in the Fraud Type field.
    Alert #
    Displays an alert number that is automatically generated.
    Threshold Overflow
    Displays the quantity by which the account's threshold level is exceeded.
    Owner
    Displays the primary person assigned to this account for fraud management purposes. This person is responsible for customer follow-up to determine whether fraud occurred.
  2. Drill down on the alert number of the fraud alert.
Viewing Fraud Alert Details
To view fraud alert details, follow this procedure.
  3. Click the Event Details view tab.
    An Account form appears with the Event Details list beneath it. The Event Details list displays detailed information about the selected alert. This information typically includes the call detail records associated with the suspected fraudulent calls. Some fraud alerts (for example, Stolen Handset) might have no associated fraud alert details.
    Some fields in the Event Details list are described in the following table.
    Field
    Comments
    Number Location
    Displays the geographical location of the number dialed in a suspected fraudulent call.
    Date/Time
    Displays the date and time of the event.
    Number Called
    Displays the number dialed in a suspected fraudulent call.
    Length
    Displays the length of the service in seconds.
    Rate
    Displays the name of the rate plan used to calculate the charge (for example, Peak, Off-Peak, Standard, Economy, or International).
    Charge
    Displays the charges for the service from the Charge dialog box.
Siebel Communications Guide Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
