Configuring Siebel Business Applications > Configuring Lists and Pick Applets > Configuring Lists and Pick Applets >
Creating a Hierarchical List
This topic describes how to create a hierarchical list. To create a hierarchical list
- In Siebel Tools, define a parent list using values from the following table.
Business Component |
Picklist Hierarchical |
- Create a child list using values from the following table.
PickList Hierarchical Sub-Area |
- In the Object Explorer, click Business Component.
- In the Business Components list, locate the business component that contains the fields that you must associate with the hierarchical list.
- In the Object Explorer, expand the Business Component tree, and then click Field.
- In the Fields list, locate the parent field, and then set properties using values from the following table.
Picklist |
Set to the parent list. |
Immediate Post Changes |
Make sure this property contains a check mark. |
- In the Fields list, locate the child field, and then set properties using values from the following table.
Picklist |
Set to the child list. |
- In the Object Explorer, expand the Field tree, and then click Pick Map.
- In the Pick Maps list, create a new pick map using values from the following table.
Field |
Choose the name of the parent field. |
PickList Field |
Constrain |
- In the Pick Maps list, create another new pick map using values from the following table.
Field |
Choose the name of the child field. |
PickList Field |
Choose the Value field. |
Constrain |
Leave empty. |
- Compile your modifications.
- To designate the parent value, add LOV values to the Parent LIC column.
For more information, see Table 57 and the topic about constrained lists of values in Siebel Applications Administration Guide.
- Test the hierarchical list.
