Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Process of Creating a Screen >
Creating a Screen
This task is a step in Process of Creating a Screen. You create a new screen in the Screens list in Siebel Tools. To create a screen
- In the Object Explorer, click Screen.
- In the Screens list, add a new screen using values from the following table.
Name |
Name of the screen. Other objects use this name to reference the screen. |
Default View |
View that Siebel CRM displays if the user clicks a page tab in the screen. You must add the view to the screen before you can define the view as the default view. |
