Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Process of Creating a Screen > Defining the Sequence That Siebel CRM Uses to Display Screen ViewsThis task is a step in Process of Creating a Screen. You can use the Screen View Sequence Editor to define the sequence that Siebel CRM uses to display views and categories in the Siebel client. The editor is a visual design tool that allows you to view and edit the hierarchy of screen views at each level of navigation. It displays the hierarchy in a tree format and allows you to move individual screen views or categories to different positions in the sequence. You cannot move an item out of the current category of the item or to another level in the hierarchy. If you do not define a sequence, then Siebel CRM orders views alphabetically. The Sequence property of a screen view displays a number to indicate the sequence in the hierarchy. Siebel Tools updates this field if you open the Screen View Editor, make modifications, and then save these modifications. To view the hierarchy that Siebel CRM displays in the Siebel client, you can sort on the Sequence column in the Screen Views list. If the Sequence property is empty, then Siebel CRM displays that Screen View as the last item in the sequence. A screen view sequence does not affect how Siebel CRM displays the view in the Site Map. It displays screen views in Site Map in alphabetical order below the screen name. To define the sequence that Siebel CRM uses to display screen views
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
