Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Process of Creating a Screen Home Page View >
Determining How Siebel CRM Displays Recent Records
This task is a step in Process of Creating a Screen Home Page View. The Recent Records area on a screen home page view displays a list of the last five records in the current screen that the user created, modified, or accessed. Recent Records only works with business components that reference the CSSBCBase class or subclasses of the CSSBCBase class. To determine how Siebel CRM displays recent records
- In the Object Explorer, click Business Component.
- In the Business Components list, locate the Recent Record business component.
- In the Object Explorer, expand the Business Component tree, and then click Business Component User Prop.
- In the Business Component User Props list, add a record using values from the following table.
Name |
Recent Record Track BC-screen home page business object name For example, Recent Record Track BC-Account Home. |
Value |
Name of the target business component. For example, Account. |
This business component user property associates a tracked business component to a screen home page view through the business object.
- In the Business Components list, locate the target business component, such as Account.
Name |
Recent Record Enabled |
Value |
Y |
Name |
Recent Record Name Field |
Value |
Enter the business component field that tracks recent records. |
This business component user property specifies the field that tracks recent records. Siebel CRM displays this field in the Recent Record applet in the screen home page view. You can use a calculated field.
- Optional. In the Business Component User Props list, add a record using values from the following table.
Name |
Recent Record Type Field |
Value |
Enter the field that Siebel CRM uses in the dynamic drilldown. The value must reference a field in the parent business component. For example, Order Type LIC in Order Entry - Orders. |
This business component user property specifies the field to track. Siebel CRM does not display this field in the Recent Record applet. You can use it to define a dynamic drilldown so that the user can navigate to a different view according to a value. If you configure dynamic drilldown in the recent record applet, then the dynamic drilldown destination objects must reference the Type field in the Recent Record business component.
For example, if the Recent Record Order Entry - Orders List Applet is the recent record applet, then the Sales Order and Web Order dynamic drilldown destination objects must reference the Type field in the Recent Record business component.
