Configuring Siebel Business Applications > Configuring Views, Screens, and Applications > Configuring a View >
Using the Views List to Create a View
You can use the Views list to create a new view. It is recommended that you use the New View Wizard because it prompts you for all necessary information and it defines all the required objects. For more information, see Creating a View.
To use the Views list to define a view
  1. In the Object Explorer, click View.
  2. In the Views list, add a new view, using values from the following table.
    Property
    Description
    Name
    Required. Enter the name of the view. References to the view are defined through the name.
    Business Object
    Required. Enter the name of the business object that the view references. The business object determines the relationship between business components that the applets reference.
    Screen Menu
    If TRUE, then Siebel CRM includes the view in the Site Map.
    Title
    Enter a text string. Siebel CRM displays this string in the window title when it displays the view in the Siebel client.
  3. In the Views list, right-click the record, and then click Edit Web Layout.
  4. In the Select Template dialog box, choose a view web template, and then click Next.
  5. In the Applet dialog box, choose the applets that Siebel CRM must display on the view, and then click Next.
  6. Review your choices, and then click Finish.
    For information about configuring visibility, see Siebel Security Guide.
Configuring Siebel Business Applications Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
