Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Business Component Field > Configuring Client-Side Import to Update a Business Component FieldYou can use client-side import to update a business component field. Client-side import uses the import functionality of the applet menu in the Siebel client. You use the object type known as the Import Object in Siebel Tools to identify the business component fields into which Siebel CRM enters data. For an example of how Siebel CRM configures client-side import, in Siebel Tools you can examine the predefined import object that is defined for the Contact business component. The Contact business component is defined as an Import Object and it contains fields that Siebel CRM defines as Import Field objects. You cannot use client-side import with a specialized business component or specialized applet. For more information, see Class Property of a Business Component, and Siebel Object Types Reference. To configure client-side import to update a business component field
Siebel CRM displays the new fields in the Select a Siebel Field dialog box. You can map them to fields in the External Data Source Field dialog box when you import data. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
