Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Link >
Configuring a Link That Creates a One-to-Many Relationship
You can configure a link that creates a one-to-many relationship. The Account/Account Note link is an example of this type of link. One Account can include many note records. The ID is the source field of the parent Account record. Siebel CRM stores it in the Account Id field of the Note record, which is the destination field. To configure a link that creates a one-to-many relationship
- Define the child business component.
- Define the destination field on the child business component.
- Define the parent business component.
- Define the source field on the parent business component.
If you do not define the source field, then Siebel CRM defaults to the ID of the parent business component.
