Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Business Component >
Determining How a Business Component Sorts Records
You can create a sort specification on a business component to determine how a business component sorts records. For more information, see How a Business Component Sorts Records. To determine how a business component sorts records
- In Siebel Tools, in the Object Explorer, click Business Component.
- In the Business Components list, locate the business component you must modify.
- In the Sort Specification property, enter a sort specification, and then save your modifications.
You must use a specific format. For more information, see Guidelines for Configuring How a Business Component Sorts Records.
- Compile and test your modifications.
For more information, see Using Siebel Tools.
