Configuring Siebel Business Applications > Configuring Business Components, Links, and Business Objects > Configuring a Business Component > Creating a Recursive Join on a Business ComponentIf you create a recursive join, then you must make sure the Alias name of the join is different from the Table Name. If you use the same name with an inner join, then Siebel Tools displays the following error message:
If you use the same name with an outer join, then Siebel Tools displays the following error message:
An inner join is a join that contains an Outer Join Flag property that does not contain a check mark. An outer join is a join that contains an Outer Join Flag property that does contain a check mark. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
