Configuring Siebel Business Applications > Configuring Tables >
Applying a Custom Table to the Local Database
After you configure a table you must apply your configurations to the local database. Note that Siebel CRM does not support a custom database trigger. If you create a custom trigger on a Siebel base table, then you must disable it before you update the logical database schema. You must redefine the trigger after you finish the update. This topic describes how to apply a custom table to the local database for databases other than IBM DB2 for z/OS. If you use IBM DB2 for z/OS, then see Implementing Siebel Business Applications on DB2 for z/OS. To apply a custom table to the local database
- Make sure no antivirus software is running on the computer that you use to run Siebel Tools.
If antivirus software is running, and if you click the Apply/DDL button, then Siebel Tools might stop responding.
- In the Object Explorer, click Table.
- In the Tables list, locate the table that includes your customization.
- In the Tables list, click Apply/DDL.
Siebel Tools disables the Apply/DDL button for tables whose Type property is External. For more information, see Overview: Siebel Enterprise Application Integration.
- In the Choose Option dialog box, choose one of the following, and then click OK:
- Apply.
- Generate DDL. Creates a DDL file instead of applying the customization.
- In the Warning dialog box, click OK.
- In the Apply Schema dialog box, complete the fields using values from the following table.
Tables |
Choose one of the following options:
- All. Update the local database to reflect all modifications that Siebel Tools makes to the dictionary. If you choose this option, then Siebel Tools compares each database object with the data dictionary and updates the dictionary, if necessary.
- Current Query. Update the local database to reflect modifications Siebel Tools makes to the tables in the current query only.
- Current Row. Update the local database to reflect modifications Siebel Tools makes to the table in the current row only.
Table space |
Leave each of these fields empty. These fields are specific to IBM DB2 for z/OS. |
16K table space |
32K table space |
Index space |
Storage control file |
Optional. The DBA provides this file. It is specific to your database. |
Database user |
Enter your database user ID, which is typically SIEBEL. Siebel Tools reads the table owner from the configuration file for Siebel Tools. |
Database user password |
Enter your user password for the local database. For example, SADMIN. The password is case sensitive. All characters of the password must be in uppercase. For example, assume the remote user JSMITH initialized the local database and used DB2 as the password. If this user applies a schema modification to the local database, then this user must use SIEBEL as the Privileged User Id and DB2 as the Password. When Siebel CRM initializes the local database for a remote client, Siebel CRM modifies the table owner password from SIEBEL to the password of the remote user. In this situation, use the password of the remote user in the password field. |
ODBC data source |
Verify that the ODBC connection in the ODBC Data Source text box is correct for your environment. You cannot apply a schema modification to any database other than the database to which you are currently connected. You cannot define the ODBC name of a different database. |
- Click Apply.
Your custom extension table and columns are now available to use in your configuration.
- Optional. To activate a customization on an Enterprise Integration Manager table, choose the appropriate table, and then click Activate.
- Test the customization.
