Configuring Siebel Business Applications > Reusing Predefined Objects > Guidelines for Reusing a Predefined Object > Guidelines for Reusing a Predefined User Interface ObjectSometimes it is appropriate to copy a user interface object. For example, if your business requirements demand a significant modification to the look and feel of the object, then copying the object and setting the Upgrade Ancestor property makes certain that Siebel CRM preserves the modified look and feel following an upgrade. For more information, see Guidelines for Setting the Upgrade Ancestor Property. If you only require a minor modification to the user interface object, then it is recommended that you use the predefined object because this configuration reduces the time you spend to configure and maintain the Siebel repository. The following reasons describe when it is appropriate to copy a user interface object:
If you copy an applet that uses a business component that references a specialized class, then use the following guidelines:
For more information, see Caution About Using Specialized Classes. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
