Configuring Siebel Business Applications > Reusing Predefined Objects > Reasons to Reuse or Not Reuse a Predefined ObjectThis topic describes reasons to reuse or not reuse predefined object. Reasons to Avoid Extensive Customization of Siebel CRMCustomization is the act of performing significant modifications to the predefined product, such as making the following modifications:
Inappropriate customization of Siebel CRM can cause the following problems:
Why Reusing Objects Is ImportantReuse involves building components that you can reuse and configure. Reuse allows you to limit the amount of customization in your deployment. Any modifications that you make to the predefined configuration must maximize reuse and allow for easy customization. Several ways exist to reuse components in Siebel CRM. For example:
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
