Configuring Siebel Business Applications > Configuring Special-Purpose Applets > Configuring a Chart Applet >
Making an X-Axis Label Vertical
You can make an X-axis label vertical so that one label does not overlap another label. To make an X-axis label vertical
- Complete Step 1 through Step 5.
- In the Object Explorer, expand the Chart tree, and then click Chart Element.
- In the Chart Elements list, locate the chart element that contains properties described in the following table.
Axis Id |
XAxis |
Type |
AxisLabel More than one XAxis element might exist. The Vertical property only applies to an element whose Type property is set to AxisLabel. |
- Set the Vertical property to TRUE.
