Configuring Siebel Business Applications > Configuring Special-Purpose Applets > Configuring a Hierarchical List Applet > Limiting the Number of Records That Siebel CRM Returns in a Hierarchical List AppletIf you define a hierarchical list applet, then the business component returns all the records that make up the hierarchy. It does this to create the hierarchy of records. Siebel CRM cannot typically return more than ten thousand records. If a query returns more than ten thousand records, then it does not display the applet and the user might encounter an error that is similar to the following:
To limit the number of records that Siebel CRM returns in a hierarchical list applet
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
