Configuring Siebel Business Applications > Configuring Special-Purpose Applets > Configuring a Chart Applet >
Configuring a Chart That Includes Two Y Axes
You can define a chart that includes two lines that Siebel CRM plots against different Y axes. Siebel CRM displays one line to the left of the graph and the other line to the right of the graph. You can use any field or function combination for the left Y-axis or for the right Y-axis. To configure a chart that includes two Y axes
- Complete Step 1 through Step 5.
- Define properties of the chart object, using values from the following table.
Data Point Field |
Define two fields that are separated by a comma:
- The first field defines the left Y-axis.
- The second field defines the right Y-axis.
Data Function |
Define two functions that are separated by a comma:
Type |
Set to Combo. |
