Configuring Siebel Business Applications > About Siebel Web Templates and Siebel Tags > About Applet Web Templates > About Grid Form Applet TemplatesA grid template simplifies the work of creating the layout of a form applet. Siebel Tools displays a grid layout template in a graphic interface that includes objects that you drag and drop from a palette to a work space. The grid layout applet web template, Siebel tag, and other features in the Web Layout Editor allow you to modify the layout of a form without directly modifying the underlying applet web template. For more information, see Using Grid Layout for an Applet. You can do the following with an applet web template that uses a grid. You cannot do this work in an applet web template that does not use a grid:
A grid layout applet web templates uses the following Siebel tags: These tags do not use placeholder tags. Instead, they provide a single container that contain all controls in the main body of a form applet. These tags allow you to use the Web Layout Editor to configure the layout of a form applet. You must use the Web Layout Editor to modify the layout of an applet that uses a grid applet web template. About the Body, Header, and FooterA grid layout applet web template includes a body, header, and footer: |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
