Configuring Siebel Business Applications > Configuring Siebel Web Templates and Siebel Tags > Configuring Web Templates to Display Menus, Toolbars, and Thread Bars > Using Web Templates to Configure ToolbarsSiebel CRM displays a toolbar as an HTML toolbar in standard interactivity and as a customizable JavaScript toolbar in high interactivity. For an application that uses computer-telephony integration (CTI), you can display another toolbar as a Java applet. For more information, see About Standard Interactivity and High Interactivity. A JavaScript toolbar object resides in the JSSApplication hidden frame, which typically does not reload during the life cycle of the Siebel application. Siebel CRM does not redraw when a page refresh occurs. The user interface part of the JavaScript toolbar resides in a visible HTML frame and redraws when the HTML frame reloads. It is recommended that the visible HTML frame is a persistent frame that reloads infrequently. HTML toolbars reside in the topmost frame in the application template that Siebel CRM reserves for this purpose. Tags That You Use with a ToolbarThis topic describes the toolbar tags that you use with a web template. SWE Tag That Specifies a ToolbarThe swe:toolbar tag specifies a toolbar where the name corresponds to the Name property in the Toolbar object definition. Siebel CRM currently supports two types of toolbars: HTML toolbars and Java applet toolbars, as defined in the javaapplet attribute. The swe:toolbar tag uses the following format:
The swe:toolbar tag includes the following attributes:
SWE Tag That Gets Toolbar ItemsThe swe:toolbaritem tag recursively gets all of the toolbar items for that toolbar from the Siebel repository. It exists between the toolbar start tag and end tag. The swe:toolbaritem tag uses the following format: The swe:toolbaritem tag does not include any attributes. Using Templates to Configure HTML and JavaScript ToolbarsYou can define an HTML or JavaScript toolbar. To use templates to configure HTML and JavaScript toolbars
Configuring a Java ToolbarYou use a Java applet to configure the toolbar. This applet includes all the toolbar controls and the threads that interact with the Siebel Server. The Java applet calls the following methods:
A set of communication protocols is defined for the communication between the Java Applet and the service. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
