Configuring Siebel Business Applications > Configuring Siebel Web Templates and Siebel Tags > Configuring an HTML Control Type > How the Siebel Web Engine Uses a Custom HTML TypeIf the HTML type of a control, list column, or page item is a custom type, then the Siebel Web Engine uses the SWF format when it displays any element that is mapped to the control, and that defines the FormattedHtml property. The Siebel Web Engine does not use the format with any other property, such as Display Name. In the SWF file, the swe:this tag can reference these properties, except the FormattedHtml property.
Format Requirements of an SWF FileYou must make sure each format specification in an SWF file includes the following parts:
You must make sure the content format meets the following requirements: |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
