Configuring Siebel Business Applications > Configuring Siebel Web Templates and Siebel Tags > Configuring Siebel Web Templates and Siebel Tags > Configuring How Siebel CRM Displays an Error That Occurs on the Siebel ServerIf an error occurs on the Siebel Server when Siebel CRM submits a form, then the Siebel Web Engine displays the same page again and includes an error message. The swe:error tag specifies the location of this error message. If an error occurs outside of a form submission, then the Siebel Web Engine continues to use the value that is defined in the Error Web Page property of the application object. You can use the swe:error tag to configure how Siebel CRM displays an error that occurs on the Siebel Server. Note the following behavior:
To configure how Siebel CRM displays an error that occurs on the Siebel Server
Format of the Swe:error TagThe basic format of the swe:error tag is as follows: The format of the swe:error tag with the FormattedHtml property is as follows:
<swe:this property="FormattedHtml"/> Example of Using the Error TagThe following code is an example of using the swe:error tag: <b><font color="red"> <swe:this property="FormattedHtml"/> </font></b> For another example, see Example Code of a Nongrid Form Applet Template. Usage of the SWEErrMsg ItemYou must use the swe:error tag instead of the swe:pageitem tag that is mapped to the _SWEErrMsg item in the Error Web Page property of the Siebel application. Siebel CRM version 7.0 and higher does not support _SWEErrMsg. |
| Configuring Siebel Business Applications | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
