| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2015 E52417-01 |
![]() Previous |
![]() Next |
View PDF |
Creating a custom client user interface in Siebel Open UI requires that you do the following work:
Creating a new presentation model that Siebel Open UI uses in addition to the metadata and data that it gets from the Web Engine that resides on the Siebel Server.
Creating a new physical user interface by creating a custom physical renderer that Siebel Open UI uses in addition to a predefined or custom presentation model.
You can use the following programming interfaces to implement these presentation models:
Presentation model class. Describes the life cycle methods that you must code for a presentation model and the control methods that Siebel Open UI uses to add presentation model properties and behavior. For more information, see "Presentation Model Class".
Physical renderer methods. Describes the life cycle methods that you must code into any renderer that binds a presentation model to a physical renderer. For more information, see "Physical Renderer Class".
For a summary of these methods and information about how Siebel Open UI uses them, see "Life Cycle of User Interface Elements".
Siebel Open UI defines each class in a separate file. It stores these files in the following folder:
\build_number\EAPPWEB\PUBLIC\language_code\build_number\SCRIPTS\SIEBEL
For brevity, this chapter states that the method does something. In reality, most methods send a request to a proxy object, and then this proxy object does the actual work.
For more information about the language_code, see "Languages That Siebel Open UI Supports".
