Siebel Financial Services Connector for ACORD P&C and Surety Guide > Data Types > ACORD XML Data Types > DecimalDecimal indicates a numeric value that meets the following rules: The value is up to 15 digits in length, excluding any punctuation (sign, decimal, currency symbol, and so on). The value is not restricted to integer values and has a decimal point that may be placed anywhere from the left of the leftmost digit to the right of the rightmost digit (e.g., +.12345678901234 is acceptable while 12345678901234567 is not). The sign is always optional. If it is absent, the value is assumed to be positive. Absence of a decimal point implies one to the right of the rightmost digit (i.e., an integer). The Decimal data type is always expressed as a Base-10, ASCII-character-set string. Example: +1234567890.12345 is acceptable, while 12345678901234567 is not. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
