Siebel Financial Services Connector for ACORD P&C and Surety Guide > Overview of Siebel Connector for ACORD XML > Using the Siebel Connector for ACORD XML > Required ComponentsThe Siebel Connector for ACORD XML requires the following components in order to implement message exchanges between Siebel Business Applications and ACORD-compliant applications:
NOTE: You should also be familiar with ACORD XML models. Additional information about these models can be obtained by visiting www.acord.org. For the purposes of this document, we assume that all these products have been successfully installed and tested for completeness by trained personnel before starting to use the Siebel Connector for ACORD XML for integration. Please refer to Configuration Roadmap for implementing integration. |
| Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
