Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Configuring Server TasksA server task is an instantiation of a server component. To run a server task, you need to run a component request, which will request that one or more server tasks run. The following example describes how to configure a server task for the EAI MQSeries Server Transport. The Siebel EAI MQSeries Server Transport is designed to provide a messaging solution to help you integrate data between Oracle's Siebel Business Applications and external applications that can interface with the IBM MQSeries. The IBM MQSeries Server Transport transports messages to and from IBM MQSeries queues. In order to run this server task successfully you need to first configure two named subsystems.
After creating and configuring the named subsystems, you need to configure MQSeries Receiver. To configure MQSeries Receiver
NOTE: For details on creating and configuring server tasks, see Siebel System Administration Guide and for details on configuring MQSeries, see Transports and Interfaces: Siebel Enterprise Application Integration. |
| Siebel Financial Services Connector for ACORD P&C and Surety Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
