| Siebel CRM Siebel Mobile Guide: Connected Siebel Innovation Pack 2015, Rev. D E52426-01 |
![]() Previous |
![]() Next |
View PDF |
This task is a step in "Process of Setting Up Siebel Mobile Connected Applications".
You can use the Siebel Open UI framework, templates, and style sheets to configure the user interface and behavior of your mobile application to address your own particular business needs. You can customize the look-and-feel of your mobile application by modifying the JavaScript files. You can also deploy your own presentation models and physical renderers that might or might not use one or more third-party JavaScript plug-ins of your choice.
The following customizations are recommended:
Set up the jQuery grid (jqGrid) renderer so that the mobile application data displays in grid (tabular) format.
Set up landscape and portrait layout for mobile applications so that the views are visible on tablets.
Set up infinite scroll for mobile applications, which is a feature that allows you to scroll through records in a list applet indefinitely.
Set up Location Services so that when you tap the Pin icon in mobile applications, a map window opens showing the location details.
Set up transitions, themes, styles, and colors as required.
For more information about the Siebel Open UI templates and style sheets, about how to customize the look-and-feel of your mobile application features, and about how to implement each of these recommendations, see Configuring Siebel Open UI.
Related Topics
