Siebel Deployment Planning Guide > Application-Level Deployment Planning > Siebel Configurator Deployment Planning > Determining Factory and Worker SizeThis topic provides information about determining factory and worker size for your Siebel Configurator deployment. This topic is part of Siebel Configurator Deployment Planning. Factory SizeAs a rule, you can assume that the factory size at run time is 75% of the incremental memory used when the customizable product is instantiated. For example, the factory size equals 75% of (Y minus X), which equals .75 times (40 minus 20), which equals 15 MB. Worker SizeThe worker size varies during run time. Generally, the worker size increases as selections are made. To size the worker, take the maximum memory observed and subtract the factory size from it. For example, the worker size equals (Z minus X) minus the factory size, which equals (50 minus 20) minus 5, which equals 25 MB. Object Cache SizeBecause the object cache size is normally quite small (for example, 500 KB), you can ignore it in your calculations. |
| Siebel Deployment Planning Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
