Siebel Deployment Planning Guide > Application-Level Deployment Planning > Siebel Email Response Deployment PlanningProcessing inbound email messages makes more demands on server resources, particularly CPU usage levels, than processing outbound messages. A single computer must handle processing of inbound messages associated with a single response group. If inbound message volume warrants it and if multiple server computers are available to run CommInboundRcvr and related components, then consider running CommInboundRcvr on a separate computer (or computers) from other Communications Server components. Combining processing of messages for multiple email accounts in a single response group can make processing of inbound messages more efficient. However, if message volume is expected to grow, then limiting the number of email accounts processed by each response group gives you more flexibility to distribute processing across multiple servers, avoiding processing bottlenecks. |
| Siebel Deployment Planning Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
