Siebel Deployment Planning Guide > Siebel Architecture Overview > About the Server Request BrokerThe Server Request Broker (SRBroker) server component processes both synchronous and asynchronous server requests.
SRBroker can run server requests on any Siebel Server in the Siebel Enterprise. For example, if SRBroker is unable to run a server request on the local Siebel Server because the required component is not enabled, then SRBroker finds another Siebel Server that is hosting the required component and runs it there. SRBroker runs by default on all of the Siebel Servers. SRBroker decides where to run a server request using the following criteria:
The SRBroker component helps provide resilient processing. As long as the required component is running on a Siebel Server somewhere in the Enterprise, then the server request can be processed. For more information about resilient processing, see About Resilient Processing. |
| Siebel Deployment Planning Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
