Siebel Deployment Planning Guide > Server Clustering Planning > Where to Use Server ClusteringSiebel Business Applications support server clustering for the following parts of a Siebel deployment:
In addition, server clustering is the preferred method for providing high availability for the following Siebel Server components:
Server Clustering for Some Components Is Not SupportedSiebel Business Applications do not support server clustering for the following components:
Server Clustering and Load Balancing Can Be Used TogetherYou can set up server clustering and load balancing on the same Siebel Server. For example, you have three Application Object Managers running on a Siebel Server: AOM1, AOM2, and AOM3. You can set up server clustering for AOM1 and AOM2, and set up load balancing for AOM3. |
| Siebel Deployment Planning Guide | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
