| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2015, Rev. D E52427-01 |
![]() Previous |
![]() Next |
View PDF |
A part is an item that you sell to the customer.
The following procedures related to parts and part management are included in this topic:
"Viewing Substitute Information for a Part"
Note: You must complete the relevant setup tasks detailed in Siebel Applications Administration Guide before using the Siebel Mobile application for Siebel Service. |
You can display part details by using the Product Inventory list.
To display part details
Tap the Side Menu icon on the application banner, and then tap Browser to display the following:
The Product Inventory list and details for the selected part in the right pane or work area.
A list in the left pane in which you can select the related items for product inventory.
Tap a part in the Product Inventory list.
To view the related items for the selected part, tap the following names in the list in the left pane:
Availability. Shows the availability information for the part. For more information, see "Viewing Availability Information for a Part".
Substitutes. Shows the substitute information for the part. For more information, see "Viewing Substitute Information for a Part".
Complete the following procedure to view the availability information for a part.
To view the availability information for a part
Tap Availability in the left pane to view the availability for the selected part.
All the inventory level availability details associated with the part appear in the work area, and all details for the selected part appear above the Inventory Level list in the work area.
Complete the following procedure to view the substitute information for a part.
To view the substitute information for a par
Tap Substitutes in the left pane to view the substitute availability for the selected part.
All the substitute availability details appear in the work area, and all details for the selected part appear above the Substitutes list in the work area.
