| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2015, Rev. D E52427-01 |
![]() Previous |
![]() Next |
View PDF |
The following task shows you how to use the processing settings for insert-transaction failures.
To define the settings for processing insert-transaction failures
Set Application Settings to FailOnError during development and testing to capture synchronization errors.
Related Topic
"Handling Insert-Transaction Failures in Siebel Mobile Disconnected Applications"
