| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2015, Rev. D E52427-01 |
![]() Previous |
![]() Next |
View PDF |
Table 1-3 lists the changes in this revision of the documentation to support this release of Siebel Innovation Pack 2015, Patchset 5. The new features listed in Table 1-3 are available only if you install and deploy Innovation Pack 2015, Patchset 5 or later. For more information, see Siebel Patchset Installation Guides for Siebel Innovation Packs (Doc ID 1614310.1) on My Oracle Support.
Note: Siebel Innovation Pack 2015 is a continuation of the Siebel 8.1/8.2 release. |
Table 1-3 New Product Features in Siebel Mobile Guide: Disconnected, Siebel Innovation Pack 2015, Rev. B
| Topic | Description |
"Adding Object Managers for Siebel Mobile Disconnected Applications" "Adding Virtual Directories for Siebel Mobile Disconnected Applications" "Process of Configuring Siebel Server for Siebel Mobile Disconnected Applications" |
Modified topics. The Siebel Mobile application for Siebel Sales is now supported in offline (disconnected) mode. |
"Configuring the Number of Records Displayed on Mobile Devices" |
New topic. Describes how you can configure the number of records displayed on mobile devices using the following Siebel CRM parameters:
"Viewing Call Planning Information" |
Modified topic. The following options are now available above the call planning calendar grid (Gantt Chart) in Siebel Mobile: 2, 4, Day, M/D, Save Template, Apply Template, and Go To Reporting. |
"Customizing the Call Planning Calendar" |
New topic. You format and customize the call planning calendar for your Siebel desktop and Siebel Mobile application in Siebel CRM. |
"Using the PCD Viewer in Siebel Mobile" |
Modified topic. The eDetailer Player has been renamed PCD Viewer. |
Creating Literature Records in Siebel CRM Associating Literature Records With Messaging Plans in Siebel CRM Defining Access to, Releasing, and Defining Messaging Plans in Siebel CRM PCD Viewer APIs |
Deleted topics. These topics have moved to Siebel Life Sciences Guide. |
Chapter 10, "Using the Siebel Mobile Disconnected Application for Siebel Sales" |
New chapter. The Siebel Mobile application for Siebel Sales is now supported in offline (disconnected) mode. This chapter describes the tasks that a user of the Siebel Mobile application for Siebel Sales can execute in online (connected) and offline (disconnected) mode. |
