Overview: Siebel Enterprise Application Integration > Overview of Siebel EAI > About Siebel EAI and Unicode Support > Transcode Business Service Usage with Non XML DataIf non XML data is exchanged, then you can use the Transcode business service in a workflow process to validate or convert data from one encoding to another encoding. You can use this technique for inbound and outbound communication. Transcode Business Service Usage with Outbound CommunicationConsider an outbound communication between a Unicode Siebel application and a non Unicode external system that uses a Unicode communication channel, such as XML. In this situation, ways in which you can use methods on the Transcode business service include:
Transcode Business Service Usage with Inbound CommunicationConsider an inbound communication between a non Unicode Siebel Database and a Unicode external system that uses a Unicode communication channel such as XML. In this situation, ways in which you can use methods on the Transcode business service include:
For more information, see the Siebel Global Deployment Guide. |
| Overview: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
