Overview: Siebel Enterprise Application Integration > Integration with Siebel EAI > Overview of Integration with Siebel EAI >
Integration Options with Siebel EAI
Depending on your requirements, the ways that you can approach your integration include:
  • Use prebuilt Siebel EAI connectors to integrate a Siebel application with your back office system or your e-commerce application
  • Use custom built Siebel EAI connectors to integrate a Siebel application with an external application
  • Use a third-party EAI product to integrate a Siebel application with an external application
  • Use a middleware solution to integrate a Siebel application
Siebel Business Applications provide solutions for each element of the EAI planning process:
  • A programmatic interface, such as COM or Siebel Java Beans, provides a tightly coupled integration for real-time data exchange.
  • An adapter, such as MQSeries or the HTTP adapters, provides a loosely coupled integration for real-time data exchange. This means that one system must be aware of the implementation details that are defined for the integration of the other system. A message or a document is exchanged between these systems.
  • Siebel Enterprise Integration Manager (EIM) provides a solution for a high volume batch integration. For more information, see About the Enterprise Integration Manager.
Overview: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
