Integration Platform Technologies: Siebel Enterprise Application Integration > External Business Components >
About Overriding Connection Pooling Parameters for the Data Source
Overriding the connection pooling parameters for the data source is supported. If connection pooling is enabled for the component but not for the data source, then set to zero (0) the following:
- DB Multiplex - Max Number of Shared DB Connections (DSMaxSharedDbConns)
- DB Multiplex - Min Number of Shared DB Connections (DSMinSharedDbConns)
- DB Multiplex - Min Number of Dedicated DB Connections (DSMinTrxDbConns) parameters for the data source
