Integration Platform Technologies: Siebel Enterprise Application Integration > External Business Components > About Distributed Joins >
Configuring Distributed Joins and Federated Fields
To configure distributed joins, you perform the following high-level tasks:
  • Implement the external data source (similar to what was done for EBCs).
  • The Datasource child object of the Table provides a hint to the object manager to federate the query.
  • Create the Join.
  • Add the fields to the business component.
To configure distributed joins and federated fields
  1. Create the Join point to your external table.
  2. Create the Join Specification.
    This is similar to what you do when creating a standard Siebel join.
  3. Add Field to Business Component.
    Add the fields from the external table to the business component using the join specified.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
