Integration Platform Technologies: Siebel Enterprise Application Integration > External Business Components > Process of Configuring External Business Components > Configuring the External Business ComponentWhen a Table object definition corresponding to the external table exists in the repository, you can configure a business component to use the new Table object definition. In general, configuring an EBC is similar to configuring a standard business component with the following exceptions:
NOTE: Substituting a Siebel-provided table with an external table can result in significant downstream configuration work, and in some cases can restrict or prevent the use of standard functionality provided for the Siebel Business Applications. This task is a step in Process of Configuring External Business Components. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
