Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel EAI and File Attachments > Using MIME Messages to Exchange Attachments >
Creating Workflow Examples
Depending on whether you are preparing for an outbound or an inbound attachment exchange, design different workflows as described in the following two procedures. For more information on creating workflows, see Siebel Business Process Framework: Workflow Guide. Outbound Workflow
To process the attachment for an outbound request you must create a workflow to query the database, convert the integration object and its attachments into a MIME hierarchy, and then create a MIME document to send to the File Transport business service. To create an outbound workflow
- In Siebel Tools, select the Workflow Process object in the Object Explorer.
- Right-click, then choose New Record.
- Give the new workflow a name and associate it with a locked project.
- Right-click, and then choose Edit Workflow Process.
The Workflow Process Designer appears.
- Create a workflow consisting of Start, End, and four Business Services. Set up each Business Service according to the task it must accomplish.
- Define your process properties.
Set process properties when you need global properties for the entire workflow.
SiebelMessage |
Hierarchy |
Leave blank. |
Error Message |
String |
Leave blank. |
Error Code |
String |
Leave blank. |
Object Id |
String |
Leave blank. |
Process Instance Id |
String |
Leave blank. |
Siebel Operation Object Id |
String |
Leave blank. |
MIMEHierarchy |
Hierarchy |
Leave blank. |
SearchSpec |
String |
[Account.Name] = 'Sample Account' |
<Value> |
String |
Default output is binary. |
- The first business service queries the Account information from the database using the EAI Siebel Adapter business service with the Query method. This step requires the following input and output arguments.
Output Integration Object Name |
Literal |
Sample Account |
not applicable |
not applicable |
SearchSpec |
Process Property |
not applicable |
SearchSpec |
String |
SiebelMessage |
Output Argument |
Siebel Message |
NOTE: For more information on using the EAI Siebel Adapter, see EAI Siebel Adapter Business Service.
- The second business service in the workflow converts the Account integration object and its attachments to a MIME hierarchy using the EAI MIME Hierarchy Converter business service with the SiebelMessage to MIME Hierarchy method. This step requires the following input and output arguments.
Siebel Message |
Process Property |
SiebelMessage |
Hierarchy |
MIMEHierarchy |
Output Argument |
MIME Hierarchy |
NOTE: For more information on the EAI MIME Hierarchy Converter, see About the EAI MIME Hierarchy Converter.
- The third business service of the workflow converts the MIME hierarchy to a document to be sent to File Transport business service. This step uses the EAI MIME Doc Converter business service with the MIME Hierarchy To MIME Doc method. This step requires the following input and output arguments.
MIME Hierarchy |
Process Property |
MIMEHierarchy |
Hierarchy |
<Value> |
Output Argument |
MIME Message |
NOTE: For more information on the EAI MIME Doc Converter, see About the EAI MIME Doc Converter.
- For the final step, set up the last business service of the workflow to write the information into a file using the EAI File Transport business service with the Send method. This step requires the following input arguments.
Message Text |
Process Property |
not applicable |
<Value> |
String |
File Name |
Literal |
c:\temp\account.txt |
not applicable |
not applicable |
NOTE: For information on File Transport, see Transports and Interfaces: Siebel Enterprise Application Integration.
Inbound Workflow Example
To process the attachment for an inbound request, you must create a workflow to read the content from a file, convert the information into a Siebel Message, and send to the EAI Siebel Adapter to update the database accordingly. NOTE: When passing the process property value for a workflow from an external application (or another business service) as the input property set, the corresponding property name in the input property set must be same name as the process property and is case sensitive.
To create an inbound workflow
- Right-click, and then choose New Record.
- Right-click, then choose Edit Workflow Process.
- Create a workflow consisting of Start, End and four Business Services. Set up each Business Service according to the task it must accomplish.
Set process properties when you need global properties for the entire workflow:
SiebelMessage |
Hierarchy |
Error Message |
String |
Error Code |
String |
Object Id |
String |
String |
MIMEHierarchy |
Hierarchy |
MIMEMsg |
Binary |
- The first business service in the workflow reads the Account information from a file using the EAI File Transport business service with Receive method. This step requires the following input and output arguments.
File Name |
Literal |
<Value> |
Output Argument |
Message Text |
- The second business service of the workflow converts the Account information to a MIME hierarchy using the EAI MIME Doc Converter business service with the MIME Doc to MIME Hierarchy method. This step requires the following input and output arguments.
MIME Message |
Process Property |
<Value> |
Binary |
MIMEHierarchy |
Output Argument |
MIME Hierarchy |
- The third business service of the workflow converts the MIME hierarchy to a document, and sends it to the EAI Siebel Adapter business service. This step uses the EAI MIME Hierarchy Converter business service with the MIME Hierarchy to Siebel Message method. This step requires the following input and output arguments.
MIME Hierarchy |
Process Property |
MIMEHierarchy |
Hierarchy |
SiebelMessage |
Output Argument |
Siebel Message |
- The last step of the workflow writes the information into the database using the EAI Siebel Adapter business service with the Insert or Update method. This step requires the following input argument.
Siebel Message |
Process Property |
SiebelMessage |
Hierarchy |
