Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > About Synchronizing Integration Objects > Guidelines for Maintaining Integration ObjectsAs the examples illustrate, you must be aware of the possible changes that can occur when you synchronize business objects and integration objects. The Integration Objects Synchronize wizard can provide assistance in managing your integration objects, but you must have a clear understanding of your requirements, your data model, and the Siebel business object structure before undertaking a task as important as synchronization. To make maintenance of integration objects easier, adhere to the following guidelines when creating or editing your integration objects: |
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
