Integration Platform Technologies: Siebel Enterprise Application Integration > Integration Objects > About the Structure of Integration Objects > Calculated Fields and Integration ObjectsCalculated fields are inactive in an integration object when it is created. They are inactive for the following reasons:
If your business needs require it, activate the calculated fields in integration objects. NOTE: Calculated fields are those integration component fields that have the Calculated flag checked on the corresponding business component field. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
