Integration Platform Technologies: Siebel Enterprise Application Integration > Integration Objects > About Integration Component KeysThere are multiple types of integration component keys:
NOTE: It is recommended to have only one integration component key for every type of key except the user key. For example, if there are two hierarchy parent keys defined for an integration component, then the EAI Siebel Adapter picks the first one and ignores the second one. |
| Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
