Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter Business Service > Configuring the EAI Siebel Adapter Business Service for Concurrency Control >
Status IDs
When using Status IDs with Modification IDs, the following behavior can be present:
- All fields must be present in the integration object instance for the Modification Key to be used.
- Only one defined Modification Key is present for each integration component. Unlike User Keys, multiple Modification Keys are not used with Status IDs.
